Q-jet question........
Old Aug 8, 2002 | 11:20 PM
jrm's Avatar
jrm
I just bought an 82 Z28 with a pos q-jet carb. Some days it will start up and idle fine, and some days it won't idle or run on all cylinders and when I turn it off, it has run-on for a second. I really want to save money and keep the q-jet, but is there another carb out there that I can get cheap that performs well and is not a pig on fuel?
Also, everything has been redone on my 91,000 KM original engine (tune-up), even a carb rebuild kit. Its just down to the carb problem, and then it should run mint.
Thanks in advance......
Old Aug 9, 2002 | 12:44 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Check the choke vacuum break diaphram for proper function.
The choke will not function right without it.
Check the Anti dieseling solenoid on the throttle linkage.
It allows the throttle to close when you turn the key off,
preventing "run-on".
69GTOby
Apr 18, 2016 02:34 PM
Zio
Carburetors
Apr 13, 2001 11:18 AM
fulo
Carburetors
Jan 28, 2001 02:04 PM
Z28HO
Carburetors
20
Jan 2, 2001 03:39 PM
Z28HO
Carburetors
Oct 5, 2000 02:58 PM
