is 23psi normal at 1000 rpm
Old Aug 11, 2002 | 10:21 AM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
hi, I've just got a vacuum gauge. Yesturday i used it to set my idle. I set it with the car in park....will this make a difference.. if i set the idle in drive??? it runs about 500 rpm in drive...ok but....i adjusted the idle mixture screws so that i had a max of 23psi.....this was the highest vacuum i could get ... does this sound normal.................i'm getting about 7-1/2 to 8 miles a gallon............. and i'm just trying to save some fuel here.........
rob
Old Aug 11, 2002 | 11:48 AM
Jester's Avatar
It's not psi, it's inches. psi is a measure of pressure.
23" is very high, altho about normal for a stock motor with a small cam.
theoratically you should set it in drive...but park is usually close enough. If you do set it in park be VERY careful not to get yourself run over.
Old Aug 11, 2002 | 02:05 PM
Car: 1983 Z28 Clone
Transmission: TH350
duhhhhhhhhh..... sorry... i meant inches.... haaha... well at least ya knew what i meant.. thanx....
rob
MSRed91Camaro
Oct 6, 2015 01:56 PM
IROCtometal
Sep 20, 2015 11:08 PM
amcnellis
Sep 16, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
