84 Berlinetta
Old Aug 12, 2002 | 11:56 PM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
84 Berlinetta
im thinking about buying a 84 Berlinetta with a great body and 77,000 k summer only usage i believe it has a lg4 engine what can i do to improve this weak performer also is this a good buy at $ 2500. Also want to know what the compression is on the heads 58cc? -The Chad
Old Aug 13, 2002 | 09:20 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
For that much money, it should be pretty much flawless.
The compression of that engine, if original, would be 8.6:1. That year had dished pistons, which lowers the static compression, even with the small 58cc chambers.
The performance-robbers of the LG4 are: single snorkel air cleaner; 2" exhaust; cast iron exhaust manifolds; lame camshaft; carb secondary air valves that don't open all the way (not true for all of them, though - check the tech articles for details); stock HEI coil and module; heads; dished pistons. In that order.
You would also need to know the rear gear ratio, which should be 3.08, but maybe not. Taller gears and a higher stalling torque converter (after modifying the above) would also improve performance.
Lbibb
May 5, 2016 12:00 AM
Linson
Oct 1, 2015 09:50 PM
rusty vango
Sep 29, 2015 02:44 PM
RacerM
Sep 28, 2015 04:25 PM
manifoldsrme
Sep 17, 2015 11:40 PM
