Holley DP throttle bracket for 700r4
Old Aug 15, 2002 | 01:15 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
do you use the stock detent cable? i tried using one and it seemed wayyyyyyyyyyyyy to tight. anyone using one of these? thanks. i dont wanna burn my tranny up.
Old Aug 15, 2002 | 03:25 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Did you press the D button to relieve all the pressure on the tv cable, then readjust?
Old Aug 15, 2002 | 06:03 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They make a bracket for that, i don't recall the part #. Seems like you have to get a certain linkage piece to bolt onto the throttle linkage too.
Old Aug 15, 2002 | 07:39 AM
LilJayV10's Avatar
Engine: 406 Roller
IHI, when ever i push the D button and then go to WOT, it pulls the cable out. thats why i was wondering if there was a longer cable i needed.
Old Aug 15, 2002 | 02:21 PM
IHI's Avatar
IHI
Have a helper sit inside the car and after you push in the D button have your friend push it to the floor, the cable will pull out quite a ways, while he still has it WOT you need to push the black stick (where the cable comes out of) with the teeth back towards the firewall until there is some tension on it. It should be hard to push it in but that's the point. once you push it back let go of the button and it's set, take her for a drive and see what happens.
Old Aug 15, 2002 | 06:49 PM
LilJayV10's Avatar
Engine: 406 Roller
i talked to holley today, they said that the thing is just really tight . i said ok. thanks for your replys
9192camaro
16
Feb 3, 2019 12:21 AM
Genopsyde
Nov 11, 2015 10:46 PM
someone972
Aug 30, 2015 12:52 AM
Dialed_In
Aug 20, 2015 01:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
