hey Jester
Old Sep 22, 2002 | 11:21 PM
radiateu2's Avatar
hey Jester
Ibought a 8016 weiand stealth intake i got it cheap but the 4 center bolts in the intake line up but are drilled on a different angle can the intake be modified to fit on a lg4 305 1987 engine . If so what do I need to do to modify the intake
Old Sep 22, 2002 | 11:43 PM
Jester's Avatar
you will need to elongate the center 4 holes enough to thread the bolts in the holes. Then, cut some angled shims to put under the bolt head, that it fluch to both the bolt and the manifold.
Old Sep 22, 2002 | 11:59 PM
radiateu2's Avatar
thanks jester
Thanks Jester sounds like an easy fix one more question the by pass hose for the heater that was on the passenger side in the back of the stock manifold where does it go? On the 8016 it doesnt havee that water passage fitting. Any suggestions
Old Sep 23, 2002 | 12:27 AM
Jester's Avatar
Run it to one of the coolant passage fittings in the front of the manifold instead.
Loudnproud86
Jul 14, 2016 12:59 AM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
Zane Story
Oct 8, 2015 12:40 PM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
Keiffer76
Sep 9, 2015 08:52 PM
