What is the main cause for stalling/flooding w/ the edelbrocks??
Old Oct 7, 2002 | 02:51 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
When I go over bumps it seems like my 1406 carb gets flooded and stalls. Also, though only sometimes, it will drop a few hundered rpm on hard braking.
In the manual it says that the cause of this is that the float level is too high and that is what will cause flooding. Should I lower the level like it is explained in the manual????
Old Oct 7, 2002 | 06:16 PM
SoSoFresh_SS's Avatar
Car: 1984 Firebird
Engine: 2.8L V6
I just took off the original q-jet and replaced it with a edelbrock 600cfm electric choke.(I believe its performance series) This was an hour ago. On my way home I encountered several problems. First of all the pedal is hard as nails. Secondly when I make a complete stop and then try to accelerate it stalls until I mash the gas harder.
Question: Can I run this carb minus the electric choke?
Question: What is the air/fuel setting?(the two screws in the front of the carb) How many turns in/out? left screw/right screw?
Right now I'm so teed-off
If you guys can help, it'll be highly appreciated.
LilCsZ28@hotmail.com
Old Oct 7, 2002 | 07:33 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Fuel pressure should be 6psi.
A higher fuel pressure will cause a too high float level
and flooding.
Bubbajones_ya
Jul 6, 2024 08:32 PM
beastin91rs
Oct 9, 2015 07:38 AM
Reddeath210
Oct 6, 2015 08:20 AM
efiguy
Sep 27, 2015 01:30 PM
john204481
Sep 7, 2015 03:22 PM
