Engine almost dies when braking hard
Old Oct 16, 2002 | 01:43 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
Why is it that whenever i brake hard the engine almost dies? I know it must have something to do with the 750 holley double pumper. It also does this when i corner hard. I have a pretty new edelbrock mechanical fuel pump. Thanks.
Old Oct 16, 2002 | 03:18 PM
Jester's Avatar
Where do you have the float level set?
Old Oct 16, 2002 | 04:55 PM
Car: 88 IROC
Transmission: auto
I have no idea. The carb was installed by someone else and i dont know much about carbs but I've recently bought a book by Vizard on carbs and intake manifolds so hopefully i'll be able to answer your question soon. I've taken engines apart before and put them together and lot other stuff, but carbs are my main weakness right now. I was using TBI before and never experienced these problems.
You think the single plane intake manifold might also have something to do with it?
Old Oct 16, 2002 | 06:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I think what Jester's getting at is if the float level is too high then fuel can slosh out of the bowl into the manifold during hard maneuvering causing a very sudden very rich condition.
Old Oct 16, 2002 | 07:26 PM
Firechick's Avatar
Car: 84 T/A,84 Bird,85 T/A Knight Automated Roving Robot
Engine: 305 HO many mods, 151C.I.D-stock,305 TPI stock for now
Transmission: 700-R4 Turbo Hydro-Matic
check your manafold vacuum line that runs to your power booster. sometimes that can do it too. Check for vacuum leaks at the base of your Holley. if you used low quality studs , when you torqued them they might have stripped. Hope that helps.
Old Oct 16, 2002 | 08:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If the power brake booster vacuum line was leaking, he'd probably have noticed hard brakes.
Old Oct 16, 2002 | 08:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Old Oct 16, 2002 | 09:41 PM
Jester's Avatar
apeiron is right about where I'm going with this. Check your float level. It should be such that, on level ground, fuel just dribbles out of the sight hole when you rock the car.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mustangman65_79
Apr 14, 2017 05:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
