New carb suggestions
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I am having some real trouble with my non cc qjet. it is on an 84 350 on my 1/2 ton p/u.
the choke doesnt work and the carb has developed a serious problem with higway speeds.
when I give it gas it goes then cuts out and comes back many times about once a second. I dont see any smoke from the tailpipe so I think it is lean but I have richened up the idle mixture screws as much as I can without causing idle problems and it doesnt help.
I will replace the fuel filter today.
the fuel pump has always made a loud noise that sounds like clanking but I thought this might be normal and has not changed since the problem started.
this started when I drove it back from buffalo (6 hrs) and it wasnt so bad at first just a slight hessitation. but eventually I couldent hold the truck at 60mph as it would just kick and sputter if I tried to give it gas.
my first question is could this be happening because the exhaust crossover passages are blocked? It didnt seem like it would cause this much of a problem and ran fine for the first 2 weeks after I changed to the blocking intake gaskets.
my second question is if and when I decide to give up with it what is the best option for a reliable new carb. should I ::
a) get a replacement 650 spreadbore from holley with the same choke and everything.
b) get a square bore 600-650 holley and a new manifold.
Thanks for any suggestions either along how to fix my qjet or recomendations for a new carb.
james
james
Transmission: 4L80E/4L80E
Try the fuel filter first.
It would be best if you could get a fuel pressure gage on it to verify fuel pressure - could also be the fuel pump or clogged fuel pickup screen.
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
ok I got the fuel filter in and it helped only slightly.
I remembered that I retarded the timing from 10 degrees to 8 for the trip and tried moving it back to 10 but this doesnt help either.
While I was doing this I also noticed the reason why the previous owner had the base timing set at 20+. the timing doesnt advance at all with rpm WHICH ODDLY ENOUGH is the SAME F_ING problem Im having with my trans am!!!!!!!!!!!!!!!!
ARRGGGG I hate computers and electronics. they dont belong on motors.
well that is a bit rash I am just having a bit of bad luck with them....
ok so I got a fuel pump and I should have it on in the morning and I also got a carb rebuild kit and will do that this weekend. and I also got a mechanical/vaccuum advance dissy from summit which should go in on thurs/fri.
maybe then this thing will run ok.
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
you are right of course and I have a non cc dissy on the way.
btw I changed the fuel pump this morning and problem solved totally.
thanks for the help guys I will definately have some questions when I rebuild the carb this weekend.
