Where in the heck is the fast idle screw on a holley SA??
Old Nov 12, 2002 | 10:46 AM
TBI305Camaro's Avatar
My idle is crazy and i need to adjust it. i checked the manual...not much about it i just cant find it. from the picture it looks like it might be near the choke but im not sure.
Old Nov 12, 2002 | 07:36 PM
82z28122's Avatar
I have the same carb but
Old Nov 12, 2002 | 07:37 PM
82z28122's Avatar
I have the same carb but I am pretty sure its in the book that came with it, but where is it idling at on start up, because I would like to know to because I need to lower mine now that it is getting even colder.
Old Nov 12, 2002 | 09:21 PM
EvilCartman's Avatar
Car: '82 Z28
Passenger side of the carb, look for a red plastic arm (fast idle cam) and the screw should be kinda tucked out of the way down below. Just run your fingers around until you feel it.
Old Nov 12, 2002 | 09:48 PM
I found it and messed with it some. at first seemed to help dramatically. I screwed it out then revved just a little and the idle went down to 750rpm...perfect....ran bad tho come to find out my timing is 4 degrees retarded...advance it back up and the idle speed goes right up with it.
with 6 degrees base it shot gas up under the hood (no cleaner they wont fit) it sprayed all over the place.
Old Nov 13, 2002 | 08:25 PM
Car: '82 Z28
Set your idle at around 650 rpm, adjust your timing, and set your idle again... You really need to get an air cleaner on there too. When the gas shot up over everything, did you see it shoot out? Have you set the float levels yet?
Old Nov 14, 2002 | 10:26 AM
yeah i saw it
it came from the drain holes i think. I adjusted the Ful pressure down and it calmed it down alot. messed with the timing some to so its running much better now and idling at a steady 750rpm
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
db057
Sep 4, 2015 07:57 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
