carb replacement problems
Old Nov 30, 2002 | 02:00 PM
KsKid's Avatar
i installed a 1406 edelbrock on an 83 berlinetta 305. since then we've been having problems with it runing to rich at idle and it has a major lack of power at WOT. should we replace the jets in teh carb or something else? when i shut it off it diesels and i have to put it in gear to shut it down. what should we do? thanks
Old Dec 1, 2002 | 09:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What distributor do you have on it now?
Old Dec 1, 2002 | 10:22 PM
KsKid's Avatar
AC delco NON COMPUTERIZED! gah i hate computers!
yeah we had to replace that too, the old one wasnt' working very well with the new carb
Old Dec 2, 2002 | 12:04 AM
SS CAM's Avatar
Car: 82 Camaro Z/28
Engine: 383 SBC
Transmission: TH350
Ks, What did you set your initial timing at? Sounds like you might just have some tuning issues. Did you adjust the carb any? Besides idle set screw does your Edelbrock carb have air adjustment set screws on it?
Old Dec 2, 2002 | 07:31 AM
KsKid's Avatar
ah geez my timing has been set over and over again by 2 different people. i forgot what its at now but ill check once i can later tonight. and the carb does have other adjustment screws to it.
Old Dec 2, 2002 | 12:56 PM
SS CAM's Avatar
Car: 82 Camaro Z/28
Engine: 383 SBC
Transmission: TH350
Ks, Here is a couple of links to read, they may help you pin point some of the source of the problem.
http://www.misterfixit.com/diesling.htm
http://www.broadwaytrans.com/services_engine_tuneup.htm
Old Dec 2, 2002 | 01:58 PM
KsKid's Avatar
thanks alot! that page is defentally going in my favorites, i'm not sure how much that will work but it gave me an idea...
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
Fronzizzle
Aug 9, 2015 01:15 PM
