tbi
Old Dec 10, 2002 | 10:19 PM
young87fbird's Avatar
tbi
ok i have tbi in my car and i dont like the idea of it cause i cant find any parts and other stuff for it so im thinkin of buyin a whole new carb and manifold for my car but dont know witch ones i should get
Old Dec 11, 2002 | 12:09 AM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
If you have the 305 TBI, you should consider the following options: One is a new throttle body, Holley makes one (The performance of which is slightly better than the original, but with a 600 to 700 dollar tag) and performance intake TBI, produced by Edelbrock, Holley and several others. The economy of these systems tends to be much better, but at the sacrafice of power. A carb setup would run you around 500-600 for the intake, carb, and distributor, possably more depending on the carb. I would suggest a Edelbrock intake, like the Performer RPM or the Air-Gap RPM. For a carb, Holley produces a great street-level 600 or 650 cfm carb, which shold give you decent numbers. If you want to go all Edelbrok (My preference, but less power) you could go with a Edelbrock performer 600 CFM. The best plan depends on what you want to do with the car. If you want an all-out dragster, you might want to spend the bucks for a high-quality carb set up. Daily driver wise, it would be more intelligent to go with a fuel injected type set up.
-Berlinetta00
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
