TPS Question ?
Old Jan 11, 2003 | 03:15 PM
86r fixr's Avatar
TPS Question ?
This is my first post, ive been viewing this board for about 6 months now and every question ive had i have found the answer to on the board and the archives. Except this question I have.
I know the TPS voltage needs to be a certain voltage (.48-.58) but ive set it at the voltage started my car, let it run, and after I shut it off, I checked the voltage again and it was lower. ?????
Well I have been racking my brain and a few minutes ago I found out that when the choke is on, it is at a higher voltage than when the choke is off. should i set the voltage when the choke is off, since it will be running with it off mostly anyways?
Old Jan 11, 2003 | 03:19 PM
385LT1's Avatar
Choke......?
TPS......?
Carb......?
Old Jan 11, 2003 | 03:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, set it with the choke off.
Old Jan 11, 2003 | 03:36 PM
86r fixr's Avatar
Thanks for the reply,
It kind of threw me for a loop . I am new to carbs and am learning as I go. I will set it choke off .
mdtoren
Aug 23, 2015 12:52 PM
BurlyChev
Aug 22, 2015 11:42 AM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
