rough startup and high idle
Old Jan 16, 2003 | 11:59 AM
dcm01003's Avatar
Car: Black 89 Camaro RS w/t-tops
Engine: 2.8L (173ci) v6
I have a 84 z28 vin H and I have these problems:
- doesn't start smooth, almost like it is misfiring, and sometimes dies
- when i push the pedal down sometimes nothing happens, when im just getting going i can put the pedal to the floor and it just pumps for a few seconds until it finally throttles.
-the idle is also running high between 1000-1500 after it warms up, but thats just the problem, it takes forever for it to warm up, i have to rev the engine for the longest time to keep it from dying
I recently had a tuneup to see if that would help(replace spark plugs/wires) had oil change and basic maint.
Any suggestions? I thought it might be the choke on the carb, but if thats the case i am just going to replace it with another one. Any suggestions for a replacement, its an LG4 Overdrive Auto, any help is appreciated. Thanks
Dave - email at dcm01003@excite.com
Old Jan 17, 2003 | 02:43 AM
Purple Monkey's Avatar
Car: 1990 Eagle Talon TSi AWD
Engine: 4G63T
Transmission: 5 speed
$20 man, buy a cheap gasket set and some carb cleaner and shine up that q-jet. most kits will come with a list of what all the adjustments should be set to. It'll be like a whole new engine for sure.
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
