What to do with vent line??
Old Jan 26, 2003 | 12:39 AM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Ok, the vent line from the fuel tank that goes to the carbon canister, what should I do with it? Cut it off? Leave it there? Plug it up? I chunked the canister so I won't be needing it....
Any help would be appreciated....
Old Jan 26, 2003 | 01:47 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
i donno, for now i put a pair of vice grips on it
Old Jan 26, 2003 | 06:04 AM
ronterry's Avatar
Car: '94 Corvette
Definitely plug it, to be on the safe side...I went for a test cruise a while back, and left mine open & if I didn't leave a two mile line of gas I'm lucky It didn't catch.
I don't know why it was pushing gas out? But I did have a HD Mechanical pump on the engine set at about 6psi???
Ron
Old Jan 26, 2003 | 08:29 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I just put one of those vaccum caps on mine, still running a 110gph mechanical pump, but no fuel has come out yet.
Old Jan 26, 2003 | 01:55 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i used some rubber fuel line and clamped it to the return line. Then I pushed in a piece of pipe that's used as a 3/8" block off and then clamped that down as well.
b4ccamaro
Jun 5, 2016 01:48 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
jerflash
Sep 23, 2015 09:21 AM
romcjr
Sep 17, 2015 05:18 PM
TBRays98
Sep 6, 2015 05:05 PM
