Anyone have a blueprint for a four barrel?
Old Jan 31, 2003 | 12:11 AM
AUTOGON350's Avatar
Car: 93 S10 blazer
I am looking to CNC machine a 4barrel throttle body for a custom injection setup I am making. I would like to make it to the same dimensions as a holley 4150. So I can use holley throttle shafts, butterflies, throttle linkage, kickdown cable, all that stuff
Does anyone have a blueprint or has anyone measured one?
Im trying to avoid taking mine off because I will need the car to get home and If I spill gas all over the measuring equiptment boss man will be pissed.
Old Jan 31, 2003 | 12:37 PM
Vader's Avatar
I think I have an AutoCAD drawing of that adapter. I'll see if I can find it.
Old Jan 31, 2003 | 03:51 PM
Vader's Avatar
Well, I found one for a 4160, but not a 4150. I think the bore sizes are different. I can send an AutoCAD *.dwg file if you can use it. It looks like this:
Attached Thumbnails Anyone have a blueprint for a four barrel?-4160basedrw.gif
Old Feb 2, 2003 | 11:18 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
That will work. Thanks a lot you just saved me a lot of trouble!!
Old Feb 3, 2003 | 11:11 PM
Vader's Avatar
Like I said, I've got it dimensioned on AutoCAD if it would help.
Old Feb 4, 2003 | 12:42 AM
AUTOGON350's Avatar
Car: 93 S10 blazer
I dont need the autocad. I really just needed the distances between the bores and the bolt holes, so that drawing was enough.
squared up the block of aluminum earlier and Im going to feed that to the machine and start cutting in about 7hours from now when I wake up.
If all goes well I will probably save $500-600 of the cost of the holley MPFI. I cant believe how much they want for those things! Its a block of metal with holes in it! How is that more expensive than a carb of equal or bigger size when the carb has a few hundred more moving parts. Perhaps its because its :hail: $C$N$C:hail: machined. ha ha ha
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
leighgrils
Oct 9, 2015 09:38 PM
Chevykid810
Sep 28, 2015 12:57 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
