Roller timing chain or gear drive?
Old Mar 1, 2003 | 07:57 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
Now that I've decided to eliminate the efi, should I use a gear drive, or should I get a timing chain? I assume the gear drive would be more reliable. Would it rob power or would both be about the same? I'm using a '99 model L31 350 so I know that either one would have to be for a factory roller motor. Does anyone have any recommendations?
Thanks.
Old Mar 1, 2003 | 08:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'd suggest not using a gear drive, or that "truck roller" chain.
Use a Comp 3136.
Old Mar 1, 2003 | 09:14 PM
drain89's Avatar
Thanks RB. Comp Magnum it is.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
camaro71633
Sep 1, 2015 10:24 AM
jharrison5
Aug 19, 2015 05:53 PM
MY87LT
Aug 17, 2015 08:43 AM
