Low speed vibration
Old Mar 4, 2003 | 02:15 PM
LT1guy's Avatar
Car: 1987 Trans Am
Low speed vibration
I'm not sure if this is carb related or not, but here goes. I have an 87 Trans Am, originally an LG4, but it does have a 350 short block swapped in with all the factory 305 accessories and hardware. Other than a tuneup, a cheesy add-on electric fuel pump (on my to do list) and the removal of the smog pump, its completely stock. It drives fine, but between about 1200-1500 rpm there is a vibration. It shakes the dash, door panels, steering...everything. It does it whether the car is moving or not, and remains as long as I'm in this RPM range. My buildup the next few months (cam, heads, intake, carb, distributor, headers, etc) will probably inadvertantly fix the problem anyway, but I'd like to figure it out and fix it before that. Any ideas?
Old Mar 4, 2003 | 02:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Probably an engine balance issue; either a bad harmonic balancer, out of balance flywheel, unbalanced torque converter, improperly balanced crank & rods, etc.
Old Mar 4, 2003 | 03:18 PM
LT1guy's Avatar
Car: 1987 Trans Am
Possibly a loose or missing convertor bolt? From the loose fasteners I have discovered on this car I wouldn't doubt it. I'll check the balancer, too...internals will have to wait til I build the other motor, unfortunately!
Old Mar 4, 2003 | 04:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check your mounts while you're at it, especially the transmission mount. Amazing what a broken piece there will do.
Old Mar 6, 2003 | 08:34 AM
MadCatX's Avatar
MY car does it at an idle at a light or stop sign\
but i think its the trans mount.
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Americanmouse
Sep 7, 2015 12:10 PM
Thornburg
Aug 27, 2015 08:28 PM
perZ
Aug 15, 2015 01:17 PM
novaderrik
Aug 10, 2015 12:44 PM
