Hood clearence
Old Mar 18, 2003 | 09:03 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Hood clearence
Hi everyone I am just about to put my new 355 in and had one question Will my stock hood work?? I have a edelbrock rpm air gap manifold with a 1 inch spacer and a holley street avenger carb. No air cleaner yet. Is there a air cleaner that will alow me to use the stock hood? any help would be great
Old Mar 18, 2003 | 10:23 PM
CamaroX84's Avatar
You'll probably have to get a drop base low profile racing air cleaner. Check Moroso. I have the same manifold, a holley carb, and a Summit air cleaner (recessed base). I have a cowl hood, but when I bring the hood down, it looks like it would barely NOT fit under a stock hood. Plus you have a 1" spacer. Hope this helps.
Old Mar 19, 2003 | 01:51 AM
Mandangelo's Avatar
Car: 89 IROC
Engine: 350 Carbed
Transmission: WC T5
Just swapped in a tree fiddy for my 305, and I have zero clearance with a Edel air gap dual plane, 750 Demon <no spacer> and a three inch element K&N drop base.
The one inch spacer is gonna put ya over the top..
BC
Old Mar 19, 2003 | 08:33 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
do you think a 2 inch cowl or an ss hood would work then?
Old Mar 19, 2003 | 01:58 PM
CamaroX84's Avatar
Yea, a 2" cowl or SS hood should work just fine. Still might want to go with a recessed base just to be safe though.
Old Mar 19, 2003 | 02:39 PM
chefdan1's Avatar
when i did my swap i did not change the intake and i ran a drop-based aircleaner and it barely fit under the stock hood. now i have an ss hood and it looks like through the vents i have about 2-3 inches to pla with so you should be fine
Old Mar 19, 2003 | 02:40 PM
chefdan1's Avatar
if you get an ss hood that is....
Old Mar 19, 2003 | 04:04 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The GM drop base air cleaner from the 60's/70's is the lowest.
You'll have to loose the 1" spacer but a nitrous plate will fit.
You can buy this base from corvette and camaro restoration sources.
Old Mar 19, 2003 | 04:07 PM
F-BIRD'88's Avatar
Lots of room with a 2.5 to 2.75" filter element.
Old Mar 19, 2003 | 04:08 PM
F-BIRD'88's Avatar
This is the common generic aftermarket base....
Old Mar 19, 2003 | 04:09 PM
F-BIRD'88's Avatar
last post:
and this is the GM base much lower.
Use a 3/8" plastic edelbrock ring spacer if you have a edelbrock carb.
The GM designed base is a superior air managemant design.
Old Mar 19, 2003 | 04:54 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Mine is close with a standard RPM with a 750 and a 1 1/2 inch drop base with a 3" tall air cleaner element. Wingnut rubs the underside of the hood...
Lose that spacer and you should be close (how much taller is the airgap, if at all?)
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
