Proform problems
Old Mar 19, 2003 | 08:13 PM
southerniroc's Avatar
Proform problems
I have been running a Holley 700 DP and decided to buy a proform for a little more air flow. I put it on and have been having problems with it stumbling off the line. I have done everything I can think of to get it out, but nothing seems to be working. I have jetted it up,went up on the accelerator squirters and cleaned the crap out of it. I bought a 50cc accelerator pump, but I havent put it on because I would hate to waste $50 bucks and that not cure the stumble. So before I try that I was wondering if there is something else I should try?
I do have a one inch phenolic spacer on it too. I even tried taking it off thinking I was getting to much air flow, but it still did the same thing.
Old Mar 19, 2003 | 09:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Try a 8.5 power valve.
Old Mar 24, 2003 | 07:45 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
i assume you have an auto trans., you should put the 50cc pump in and change the cams to tune out the bog.
if you have a manual trans you dont need the pump.
also if you could get a vac. guage or know someone who does that would help you select a power valve.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
