switching from vacuum to mechanical secondaries
Old Apr 10, 2003 | 09:17 PM
Killogy's Avatar
Car: 87 Firebird Formula
Engine: 355
Is there anyway that I can rig up my stock quadrajet so its mechanical secondaries instead of vacuum? Just curious..
Old Apr 10, 2003 | 09:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It already is mechanical. It has an air valve to regulate the mixture; but the actual secondary throttles are mechanical.
Old Apr 11, 2003 | 08:56 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
If you do remove the air valve from the carb you'll have to max out the acellerator pump and you'll also have to run a very good converter to avoid the bog that you'll get.
If you have a big engine and light-weight car you can probably get away with it no problem.
If you have a 305 in a 3300+ lb car, then you'll probably not be happy with the results.
Old Apr 11, 2003 | 09:52 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If you'd put a real motor under it, the secondaries would open!!
Old Apr 11, 2003 | 10:09 AM
Killogy's Avatar
Engine: 355
I get a new motor on friday so don't worry
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
