spacer ?
Old Apr 20, 2003 | 09:08 AM
86r fixr's Avatar
spacer ?
I have been thinking about getting a 1 " spacer.
The only ones I have seen are like adapters for different carbs.
I still have my Quad, where can I find just a spacer that I can bolt to my manifold.
Old Apr 20, 2003 | 09:34 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I've seen several at Autozone. You could also check Summit and Jegs.
Old Apr 20, 2003 | 09:45 AM
86r fixr's Avatar
Thanks for the reply, I actually bought one from autozone ,it was the four hole one. What was wierd about it was ,in the back it had the hole were you would screw your fuel line at ,I wasnt sure if that would work or not (just cap it ?)
Old Apr 20, 2003 | 09:54 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I'm pretty sure thats not for a fuel line, It's probably for a vacum port if you need it. If you don't need it just cap it off.
Old Apr 20, 2003 | 03:39 PM
86r fixr's Avatar
It maybe a vacuum line , it is a metal line (the same as the one that goes into the fuel filter) ,anyways,If I cap it off would it be best to cap of the one on the spacer, or the one on the carb
Old Apr 20, 2003 | 06:42 PM
flyway190's Avatar
Sounds like the power brake vacuum line. Just leave everything on your carb the same and plug the hole on the spacer.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
