Dies In Idle When Choke Comes Off
Old Apr 19, 2003 | 02:55 AM
Trevor K's Avatar
I have a 87 Z28 - non-CC quadrajet that was just rebuilt last summer, worked perfect then.
I had it running after I pulled it out, and it ran perfect. Never got to drive it, but when it was parked it ran perfect.
Now, when I started to drive it today it will not idle when the choke comes off. Once the choke comes off, it sputters around 500RPM's, and then dies.
After the car is all warmed up it will die if left in park for a minute or so (The time it takes me to unlock my garage door and open the big door to drive in).
Even at lights with it in drive it still seems to want to stumble/die (I hold my foot on the brake and press the gas slightly to bring it up to just over 500RPM)
I tried the idle adjustment screw, hoping it backed out, but didn't fix the problem.
Any ideas???
Old Apr 19, 2003 | 11:28 AM
86-350's Avatar
When you played around with your idle adjustment screws what was the procedure you went with?
Old Apr 19, 2003 | 04:06 PM
Trevor K's Avatar
I thought since I have a non-CC carb, I wouldn't need to ground anything in order to adjust the base idle, so I just adjusted the screw (On the drivers side of the carb).
I had it started again today, but it's running like crap still. The fuel looks to spray out right (When I look down into the carb), but it's REALLY rough (The whole engine shakes) when it idles to 500rpm's.
I'm wondering if this is possibly electrical?
Old Apr 21, 2003 | 02:34 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
This is just an observation, but if the choke shuts off and it makes the car run worse, wouldnt that mean the car is already incredibly lean at idle?
Old Apr 21, 2003 | 08:59 AM
Trevor K's Avatar
Yes, it's lean at idle.
Turns out my intake manifold gasket bit the dust, so I'm gonna replace that tonight.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
