Edelbrock on a spreadbore manifold
Old Apr 26, 2003 | 07:32 PM
capn_crash84's Avatar
If i was to put a squarebore edelbrock performer series carb (ex. 600cfm) on a spreadbore manifold, should it run like crap or not make a difference? The spreadbore has the bolt holes so it bolts right up. Theoretically, lets say i already tried this, and the plugs foul out. Did the difference cause this?
Old Apr 27, 2003 | 10:22 AM
Cuno's Avatar
Not sure if it would cause your plugs to foul...I suppose it could. They sell a squarebore to spreadbore adapter you can use to mount the carb to that intake...not real expensive either. You may want to look into that.
Old Apr 27, 2003 | 12:09 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It will work fine if you remove the divider holes O O { | }
o o ( | )
This way the the throttle blades can acutually open up if you dont they will not open and foul the plugs. I did this to my lg4 manifold. It basicly makes it like any other replacment manifold minus 4 extra mounting holes.
Old Apr 28, 2003 | 01:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
By this, I assume you mean "the spreadbore manifold", meaning it's an aftermarket manifold.
I'm running a squarebore Holley on an Action+ manifold that has both the spreadbore and squarebore patterns drilled/tapped in it. I had an adapter on it for the last half of last season, took it off this spring and don't regret it. The extra height did nothing for me.
Pac J
May 17, 2020 10:44 AM
sreZ28
Oct 22, 2015 08:21 AM
Night rider327
Sep 25, 2015 04:47 AM
Rally Smith
Sep 14, 2015 06:59 PM
