jets
Old May 6, 2003 | 09:54 PM
jwilds469's Avatar
Car: 82 z28
Engine: 350 carbed
jets
what the best jets for my holley 750 dp, i just a 350, with performer intake and cam.
Old May 7, 2003 | 07:44 PM
Damon's Avatar
Until you have proof-positive that you need to change jetting stay with stock calibration. If it's a new carb- dont' touch it. If it's a used one with an unknown history then it's worth taking off the fuel bowls and making sure the jetting is stock for that carb. You can get specs on all Holley carbs off their website, including stock factory jetting.
You may be running a little fat (typical of universal replacement performance-oriented Holley carbs) but not so much as to cause any noticable "seat of the pants" problems or noticable performance loss.
Carb tunign is the LAST thing to do after you make sure everyting else is correct.
Old May 7, 2003 | 07:52 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
That being said and good advice, #70primary and #80 secondary
jetting seems to work well in these carbs most of the time.
For street/strip and at near sea level. If you're at a real high altitude you may want to lean it out a bit.
This is stock jetting in some models of 750 DP'ers.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
69GTOby
Apr 18, 2016 02:34 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
mackjar66
Sep 14, 2015 01:17 PM
