tbi to carb conversion and cam options
Old May 15, 2003 | 01:32 AM
seracam89's Avatar
how to update fuel system and alll neccessary alterations for a fully gfunctional carb conversion. inc. fuel pump and adj reg placement. comp problems, emitions problems and solutions. do i need to use the distributor off the carburated engine. can i use the tbi dist. can i switch the gears on dist. also what is the largest cam lift and duration i can install in a L69 h.o. which was bored out to 350
note this is an 89 rs
i have a L69 from AN 84 with a carb that im swaping into the rs. would have maintained tbi but i ran into the differant intake bolt angle problem. what do i need to do to the fuel system to be functional
Old May 18, 2003 | 03:34 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
lemme get this straight...... you boared a l69 305 out to a 350?
MustangBeater20
Oct 29, 2022 09:20 PM
junkcltr
Aug 2, 2019 11:12 PM
theurge
Aug 21, 2015 12:46 PM
stalkier
Aug 13, 2015 12:59 PM
stalkier
Aug 7, 2015 04:49 AM
