considering an 86 camaro
Old May 15, 2003 | 08:30 PM
srwolf73's Avatar
im considering buying an 86 camaro sc and wanted some info on it
it is the 4bbl carb non ho
does it have a computer in it and if so willl it give me trouble if i start upgrading the engine
also how do the heads flow on that model ?
Old May 15, 2003 | 10:25 PM
guza's Avatar
Car: 1985 Berlinetta
Engine: 305 4BBL
I'm sure it has the computer in it. My 85 does! You must be carefull with mods, some will not make the computer happy. Talk to a reputable cam company tell them your info. They can match a cam to work with your computer.
The computer controls mainly the mixture control in the carb and the timing advance.
Read this thread five7kid explains well. https://www.thirdgen.org/techbb2/sho...hreadid=178394
Old May 15, 2003 | 10:29 PM
Dirty Rob's Avatar
Buy it!!
Do you really have anything better to do with your money?
Welcome to the boards.
Old May 15, 2003 | 10:32 PM
lthlcamaro's Avatar
Hey man,
I have a 1986 sport coupe
4 barrel carb -- 305 V8
bought it less than a year ago - i love it
go for it
Old May 15, 2003 | 10:47 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Yes, it has a computer controlling the idle and mid range fuel mixture, and the timing. As for giving you trouble, you can give it quite a bit before it chokes up. Mine is doing fine so far, and I have nearly doubled the horsepower! I think my cam is on the borderline of causing problems though!
The stock heads flow like stock heads! Not all that well.
I bought my 84 with the same engine in it about 5 or so years ago with about 160,000 miles on it and now the car has almost 217,000 on it! There hasn't been much go wrong with it either. The only major thing was the rearend, and I happened to pick one up for practically free! The engine was still running strong (for a LG4 305!) when I pulled it to put the 355 in!
I recommend buying it if the price is right!
Old May 16, 2003 | 09:06 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
My donor car was an '86 SC. My car is more that than it is '82 now.
The stock heads respond well to porting and valve spring upgrade. Increasing the intake valve to 1.94" is another popular improvement. If you put in a cam with healthy lift, then consider converting the press-in rocker studs with screw-in. I handled all of those issues by getting World Products S/R Torquer 305 heads.
Exhaust and air cleaner upgrades are must-do items. Even if you don't do anything else to the engine, those two are big performance restrictions. The L69 dual-snorkel air cleaner (becoming harder to get) and '86-'90 TPI single-cat application exhaust goodies (headers, cat, & cat-back) are good ways to address those issues.
Since it is a computer-controlled engine, sticking to computer-compatible cams is a good idea. Mine idles at 500 RPMs in drive, and pulls to 5500 easily - it will rev to 6300 if you ask it (that's about 90 MPH in 2nd with my gearing). A higher stall torque converter is a good idea if you go over about 210 degrees duration @ .050" lift with the cam.
If you get the engine to rev higher than it does now (i.e., cam & exhaust upgrades), then the ignition becomes the weak link. Distributor module and coil upgrades take care of that.
Then there's the ever-popular "bore kit" - aka "350 block".
Old May 22, 2003 | 06:47 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
also check RPO codes in the arm rest compartment.
Found out my 86 sc had 3.23 gears instead of the usual 2.73
Also Rpo codes will tell you about your chassis, sway bars, springs, brakes, etc. My SC had about the worst parts in this area when I got it.
Look for "1LE"
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
