this cant be good!! can i fix it??
Old Jun 20, 2003 | 07:31 PM
icebird_1981's Avatar
this is a pic of my carb and the spot were i have gas leaking from not much really small amount. is this possible to fix with a tad of silicone? or am i stuck with rebuild i mean if i use silicone it would just be a bit and when i do get a rebuil in the winter i could just take it off. what u guys think????? also could that leak effect my cars start up???
Old Jun 20, 2003 | 09:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's the accelerator pump. IF it is just a gasket-type leak, then replacing the pump diaphragm will be all that's required to fix it. If there is cracked metal, you'll either have to replace the float bowl or the pump housing (more likely the bowl). Silicone typically isn't a good idea - it gets into places it doesn't belong, and it's better to fix the problem than it is to patch it.
If it is leaking because the diaphragm is blown/torn, then it could make the engine harder to start since the pump wouldn't squirt into the carb when you're "pumping" the accelerator to start the engine.
Old Jun 20, 2003 | 10:16 PM
kool so i dont have to take off the whole carb just take off that part???? could u please point on the pic were on the carb i should un screw to take off that part?? i really dont have a clue.
thanks
jason
Old Jun 20, 2003 | 10:47 PM
k been doing alot of hunting on this and i think it is the pump diaphragm, do i have to take off the whole carb to get to this? and the pic below is the thing i will need right, i dont think that one is the right on but its just and example. is it a simple unscrew take out old and put in the new (like changeing a gasket???)
Old Jun 21, 2003 | 02:49 PM
k well i fixed it i stopped the leak i just hope i put the thing in the right why, but it did not solve the start start and puse problem.
86IROC112
Apr 9, 2016 10:20 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
jackhammer
Aug 15, 2015 10:04 PM
Amillionoh7
Aug 7, 2015 01:24 PM
