Switched carbs
Old Jun 22, 2003 | 11:35 PM
Naphead's Avatar
Switched carbs
Well I took off my old carb and tried my friends rebuilt 85 cutlass 442 carb, I switched the distributer to vacum (like his). it idels great, runs good, but when I jump on the throttle it bogs down, I not sure, but I think its right when the 4 barrels are supposed to open. I can have the pedel floored down and just watch the rpms go down (like half throttle). I made sure I was getting full throttle and everything. Could this be a computer problem? Well thanks.
Old Jun 23, 2003 | 05:16 AM
EvilCartman's Avatar
Car: '82 Z28
Try swapping in your old metering rods and hanger to the rebuilt carb.
Old Jun 23, 2003 | 04:47 PM
Naphead's Avatar
I just tried that and I still have the same problem. This rebuild carb also has bigger injectors. Thats all I know about the carb.
Anything else I can try?
Old Jun 23, 2003 | 09:25 PM
flyway190's Avatar
Let me make sure I'm understanding what you did. You have an LG4 and you replaced your computer-controlled q-jet and distributor for a non-cc q-jet and distributor? If so then your computer's not doing much of anything and you probably need to adjust the tension of the secondary air valve spring. Check the tech articles section or do a search on this board for the procedure on that.
Old Jun 24, 2003 | 07:32 PM
Naphead's Avatar
The carb that I am using now (85 cutlass's) is computer controlled, but I tried ajusting the screw, and it didnt seem to work, but thanks for the reply. LoL got anything else I can try?
thanks
C-ya
Old Jun 24, 2003 | 08:36 PM
flyway190's Avatar
If you're using a vacuum advance distributor, try swapping your original back in and see if the problem goes away.
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
stalkier
Aug 21, 2015 01:54 AM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
