What makes the Choke light com on?
Old Jun 24, 2003 | 01:33 AM
Charlo's Avatar
Just trying to figure out what I wired wrong but my choke light comes on and my idle drops real low(250-350rpm) then the engine dies. The problem is I converted to TBI. I assume I mixed up some wires but what can make the choke light come on?
Charlo
Old Jun 24, 2003 | 06:57 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
On the third gens the Choke Light is really a Alternator Light. If it comes on your Alternator is not puting out enough. So if you are below 500 rpms it may not be puting out enough or it is about ready to die.
phil
Old Jun 24, 2003 | 12:50 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
The Choke Light usually means engin RPMs too low. If it comes on when the RPMs are OK, then you got a bad Alt or some other electrical problem.
Take this problem to the TPI/TBI tech board, they can tell you how to fix your IAC(idle air control). Fix the idle speed problem BEFORE worring about a bad alt.
Old Jun 25, 2003 | 12:16 AM
Charlo's Avatar
It seemed like it only came on when the voltage was low I just couldnt figure out why it said choke. Thanks guys.
Charlo
92camaroJoe
Jul 29, 2023 07:57 PM
Fronzizzle
Aug 17, 2015 02:52 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Omega
Aug 10, 2015 12:46 PM
