tuning issues??
tuning issues??
i think my carb is way out of tune.
i have a holley 750 DP on a mildly built 350
the car starts awesome, but after it runs a while, it has a really bad starting problem. it smells like its running really rich, and when it finally starts a huge black cloud of smoke comes out of the exhaust.
the car also seems to bog for a very split second just off from idle.
i dont think the jets in the carb are stock, as i got the carb used...and it was on a very well built 383.
how should i start tuning it?
i've never even owned a holley DP, let alone try to tune one for performance
do these symtoms seem like tuning issues, or should i start looking for something else to make it start better when warmed up?
Transmission: 4L80E/4L80E
1) Check the float levels. Pull the sight plugs, start it up, adjust if necessary to just have fuel dribble out the bottom of the holes.
2) Buy a vacuum gage. You'll need to be able to watch the manifold vacuum while under the hood and while driving.
Look around on www.holley.com . They have more on what you'll need to do. Come back with any other questions you have.
Street Lethal
Apr 30, 2019 12:14 PM
NBrehm
Aug 25, 2015 11:49 PM
