why is my gas milage getting worse?
Old Jul 11, 2003 | 12:05 AM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
i have a 79 chevy truck 350 in my car. i also have an edelbrock 600 cfm electric choke carb and headers. my milage has been pretty descent. my carb and timing was set by a professional gm mechanic i know. i also put on new plugs and wires a couple months ago. and i adjusted my valves and then my gas milage just went way down. so i re adjusted them and it seems to be even worse. i was told adjusting my valves wouldnt effect my gas milage that bad so the only other thing i can think of is my carb?? what would cause my gas milage to get soo much worse? what should i check? thanks alot
Old Jul 11, 2003 | 06:46 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check for things you disturbed during the valve adjustment - vacuum lines, spark plug wires, etc.
Old Jul 11, 2003 | 10:33 AM
bad_ta_05's Avatar
Car: 85 trans am
ok, is there anything on the back of the block on the passenger side i might have messed up? that was a pain to get off so i might have jerked a wire loose or something
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
92firebirdguy
Sep 1, 2016 07:53 AM
tonys91rs
Oct 10, 2015 03:31 PM
earlpote
Sep 12, 2015 11:55 AM
