vac. leak?
Old Jul 13, 2003 | 01:24 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
vac. leak?
i have a holley 670 s/a and one problem that is annoying me is if i turn down the idle all the way the car wont stall. it should stall right? to me that sounds like a vac. leak is this correct??
also she will stall when i turn in the air/fuel screws in all the way that's normal correct?
thanks
Old Jul 26, 2003 | 09:22 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I see no one has responded.
Your choke high-idle cam may be picking up when the regular idle speed screw is backed off all the way.
If that's not the case, you might take the carb off and turn it over. Check the opening of the secondaries, they might be held open too much.
Other than that, I wouldn't worry about it if it runs okay otherwise.
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
