Midrange feels flat - Q-jet experts w/in >>
Old Jul 31, 2003 | 03:18 PM
novadude's Avatar
Car is a 1965 Chevy II. Mostly stock 327 (200 deg cam, perf intake, headers), w/ a PG (yuk!), and 3.08 gears. Convertr stalls at ~1800 rpm.
Carb is from a 1980 305. Jets are 71 w/ a 42 prim metering rod, DR sec rods, and H hanger. Carb was just rebuild w/ float at 1/4". Fuel pump is a new Carter 6900 mechanical unit. Air door is set at 3/4 turn. Vaccum can is "2-3 sec" unit.
Here is the scenario:
Mashing the gas off idle gives no hesitations or stumble. Car begins to pull strong, but revs slow, due to a 1.82 1st gear and 3.08's. When it gets to about 3000-3500 rpm, it feels like it goes "flat". At 4000 rpm, it starts to pull again like someine flipped a switch, and pulls until 5000-5200, where the small cam and heads give up.
What is going on here? It did not do this with the previous carb, which was a 1850-3 Holley. Could it be that the DR's are too rich on initial opening? Could it be that the vaccum can is not "damping" the initial secondary opening?
Remember, 40 mph is like 3000-3500 rpm in first gear, so the engine spends a lot of time at WOT under 3000 rpm accelerating the car to 35-40 mph. This is a bit different than most A3/A4/manual trans combinations.
Help! What should I do?
Old Aug 1, 2003 | 11:35 AM
novadude's Avatar
BTTT
Old Aug 1, 2003 | 05:21 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I'm almost positive....
You're vacuum secondaries are set too tight. It's taking a great amount of vacuum pressure to open the secondary flap (plate), and at 4000 RPM.... this is where the engine is finally getting it to open, feeding it a rush of more air etc.. (thus more power only at this particular RPM)....
Loosen the the secondary plate a 1/4 of a turn for at first, then give it a test drive. If it's still holding back until a later RPM..... loosen it somemore. Keep loosening until you start to 'bog' a little, then you know you loosened too much, so tighten it back up a drop til the bogging stops.
If the quadrajet came off of a stock 305/350, and you're putting it on a mod motor (even if it's basic mods).... resetting the secondary plate is a MUST!!!
Old Aug 4, 2003 | 08:32 AM
novadude's Avatar
I don't think that's it, but I guess it would be worth backing off tension completely to see what happens.
I have played with many Q-jets, and it seems that all of the ones I have used before have always liked A/V tension to be between 1/2 and 1 turn. I have never tried taking this one below 1/2 turn.
Old Aug 4, 2003 | 06:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You're leaning out as the AV opens. Get a lower-letter hanger like a "B" to pull the secondary rods out of the secondary jets more, relative to AV opening.
Old Aug 6, 2003 | 08:10 AM
novadude's Avatar
You think that is the problem? I'll try a "B" hanger and see what happens.
Thanks!
Old Aug 6, 2003 | 08:29 AM
five7kid's Avatar
The other possibility is that the AV hanger cam is worn. It's the plastic thing that lifts the hanger as the AV opens. Check that, and if it doesn't appear to pull the hanger/rods up smoothly, replacement may be in order. They are available here http://www.carbs.net/cams.asp , p/n 85-104.
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
69GTOby
Apr 18, 2016 02:34 PM
xbazzarex
Exterior Parts for Sale
16
Oct 6, 2015 08:42 PM
ASE doc
Sep 22, 2015 03:13 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
