TBI to Carb How - To?
Old Sep 3, 2003 | 08:03 PM
Trickie's Avatar
I would like some info on converting my TBI to use a carb.
Is there a how to listed anywhere for this?
Benefits, drawbacks?
I have a swapped 350
Old Sep 3, 2003 | 10:08 PM
Firechick's Avatar
Car: 84 T/A,84 Bird,85 T/A Knight Automated Roving Robot
Engine: 305 HO many mods, 151C.I.D-stock,305 TPI stock for now
Transmission: 700-R4 Turbo Hydro-Matic
Hi Tricki. You'll need a new intake, correct cfm carb, and a new fuel pump. The stock fuel pump on fuel injection is electric, and in the tank. The fuel pump on a carb vehicle is on the passanger side of the block. You will eliminate some wires in the process. As far as the mods you would have to make for the mechanicle fuel pump, I wish I could tell you. Hopefully someone could answer that for the both of us.
Old Sep 4, 2003 | 09:37 AM
dennis6's Avatar
Car: 1991 Camaro RS
Don't need a new fuel pump, all you need is a mallory #4309 regulator. There are a few others that work, but it must be a bypass style or you will burn up your fuel pump.
You will also need a HEI vacuum advance distributor, check ebay or junkyards.
Advantages: More power, easier to mod engine, cleaner engine bay.
Disadvantages: Worse starting in winter, about 3mpg less in fuel economy.
Old Sep 10, 2003 | 09:42 PM
nathan2003's Avatar
Car: Camaro
hey theres a good technical article on the tech articles off the homepage of thirdgen... it gives you the lowdown on what to do and all the basics... you should check it out before starting...
Old Sep 11, 2003 | 05:03 PM
Trickie's Avatar
thanks nathan
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
