CCC Q-Jet IAB O-Rings
Old Sep 18, 2003 | 09:52 AM
flyway190's Avatar
Anyone know where I can get some O-rings for an IAB valve? The rebuild kit I used didn't come with new ones. I'd rather not buy a whole new kit, but if anyone knows for sure that a certain brand comes with them I'd like to know. Thanks.
Old Sep 18, 2003 | 06:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Mine didn't look like o-rings, but lip seals.
Hearing they weren't in the rebuild kit isn't good news. Mine are a little torn up, and I was counting on the rebuild kit that I'll be getting soon before the emissions test is due would have those little babies in it.
Old Sep 18, 2003 | 06:46 PM
flyway190's Avatar
It was a Walker kit, nothing was labeled and it had some small o-rings that fit around but it seemed like they were too thick. There were some little seals that looked similar to the original IAB valve seals, but they were exactly similar to the seals at the accelerator pump and somewhere else i forget and I replaced those first. I suppose there just weren't enough of them.
Old Sep 19, 2003 | 09:21 AM
Keith_Indy's Avatar
Car: 87 Firebird Formula
Engine: 305 LG4
I would take your original o-ring to NAPA or some other good auto parts store and see if they have a replacement. I've had good success in the past doing this with other o-rings.
You could also give this place a call. http://www.carbs.net/quadrajet.asp
Old Sep 19, 2003 | 10:13 AM
flyway190's Avatar
I wish I could but I forgot to pull the IAB valve out of the air horn before I dipped it in carb cleaner so there wasn't much left of them.
Old Sep 19, 2003 | 10:26 AM
flyway190's Avatar
You know, I never would've thought...
Echlin Fuel System Idle Air Bleed Valve O-Ring
Thanks for the replies!
gixxer92
May 18, 2017 11:20 AM
69GTOby
Apr 18, 2016 02:34 PM
BOOT77
Sep 16, 2015 08:37 PM
BOOT77
Sep 5, 2015 03:55 PM
2QUIK4U
Aug 26, 2015 04:40 PM
