choke adjustment
Old Oct 1, 2003 | 07:25 AM
WideOpenVTwin's Avatar
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
choke adjustment
Hey,
I'm kinda new to holley carbs, so please help me out with something. The electric choke was hooked up wrong on my holley 4160, so I thought I got it connected correctly (The linkage was jamming against the fast idle cam). Now, when I start the car the choke comes on and the fast idle kicks in just fine, but if I bump the throttle at all, the choke pops off and the fast idle turns off. If I don't bump the throttle, the choke slowly cuts off like normal. I think I have the linkages hooked up correctly, could anything else be causing this problem?
Old Oct 1, 2003 | 08:22 AM
82camaro's Avatar
Car: 82 camaro SC
When you bump the throttle, a rush of air hits the choke plate and opens it. What you describe is normal. The holley electric choke system doesn't work quite as nice as a q-jet. If you think the choke is coming off too early, adjust it richer(loosen the 3 screws and rotate. Don't go too far or it will 'load up' and flood.
Old Oct 1, 2003 | 08:26 AM
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
Yeah, when I turn it richer the butterfly is closed too much and it runs far too rich. I think it might be time to go w/ a manual choke
Old Oct 2, 2003 | 06:06 PM
82camaro's Avatar
Car: 82 camaro SC
How does it run when the choke kicks off? If it still runs OK, I'd just leave it alone.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
