can't figure this one out.
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
got a good one here. my car is running rich and im fouling out the plugs but im backfiring thru the carb like it's lean and it will barley idle
i changed the plug wires and the power valve, played with the a/f mixture and checked the timing. the fuel bowl level is good. the dist. cap looks good im lost here
i was told could be valves, lifters,dist, or the carb took a dump. the carb is a holley 670 s/a
any help?
thanks
any help?
thanks
