305 build-up
Old Nov 1, 2003 | 03:55 PM
matt_82transam's Avatar
Car: 82 T/A
Transmission: th350 w/ high stall C.
305 build-up
I currently have a rebuilt 305 from a 1978 chev truck and going into an 83 trans am. I am wondering what I shoould expect powerwise. I have an edelbrock eps intake manifold and I am using stock heads that have been ported to match the intake ports through the means of felpro gasket90314-1. The deck has been shaved to get an extra point of compression bumping it up to 9.5:1.
-I Have a cam with 223/223 duration and .447/.447 lift(I,E)
-I also have 3.08 gears and 1 5/8 shorty headers.
What kind of power numbers should I see with this route?
around 15.2 in the 1.4 mile w/2800lb trans am?????
Old Nov 1, 2003 | 06:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Probably not. Truck 305's had teeny valves. Although you gasket-matched the intake ports, it's going to be restrictive well before the lift you're considering.
Put some 416 or 601 heads on there, then you'll probably make your goal.
Old Nov 2, 2003 | 03:54 PM
stupid4901's Avatar
I have a relatively stock 305 and put a ZZ4 cam in it with no other changes to the springs or anthing and dropped a half second of my ET. Thats what I would go for.
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
