Is a 750VS too much for my L69?
Old Nov 10, 2003 | 01:56 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
My computer took a dump. I have a 750VS Holley to put on it and a non-CC dist. Is this too much for a L69/5-speed combo? If so, could I jet it down to make it work ok? I need help ASAP because my car is barely running right now and I drive about 25 miles to work on way every day. Thanks in advance.
Old Nov 10, 2003 | 05:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's more than it needs, but not too big to work.
Jetting is basic tuning. Regardless of what engine you intend to put a carb on, you should plan on rejetting to get it tuned properly.
You may need to play with secondary springs to get proper full throttle performance w/o bog.
Old Nov 12, 2003 | 12:38 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You'd want to change the Qjet intake manifold to a square flange holley patterened intake like a Performer EPS for best results.
( A weiand Stealth Dual plane would be another good choice)
The 750VS carb should work pretty well, as it is on your motor.
It may want slightly leaner primary main jetting.
72 is stock. try it as is. then pickup a set of #70 main jets and try that. Usually works pretty good like this.
Chuck84TA
Jul 15, 2016 09:05 PM
PurelyPMD
May 5, 2016 04:57 PM
Night rider327
Oct 13, 2015 01:47 AM
leighgrils
Oct 9, 2015 09:38 PM
clemsparks
Carburetors
Nov 10, 2001 12:13 AM
