possible symptoms of a vacum leak
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
okay, my car is an 84 Z with an lg4. whenever i punch it from a stop it hesitates. it will lunge forward then bog down then lunge forward and so on. after a few seconds it will finally go.
when i first start my car up it idles at like 1500 for like 4 min then finally goes down to like 800
and finally sometimes when im at a stop just idiling the car with stutter a little bit.
any help is appreciated.
Car: 83 Z-28
Engine: LG4
ok that does make sense. sometimes when i warm the car up in the morning and let it idle blackish water will come out. the aircleaenr also smells a little like gas. does being to rich cause a car to diesel?
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
My car does the same thing. I fixed my vacuum leaks so it doesnt shake anymore. Yet it does hesitate sometimes and idles wrong. Im having it looked at on tuesday.
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
Dieseling is caused by high compression on low octane fuel or too high a heat range sparkplug.:rockon:
Car: '82 Z28
Engine: 350HO
Transmission: M4
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
dieseling is caused by hot spots, and high compression from carbon buildup, not the engines compresssion, try turning down the idle (by closing the blades) and richening the idle mixture to bring the idle speed back up, use a vacuum gauge to get the highest vacuum at idle and the dieseling should go away unless you have crazy carbon buildup or the car is running too lean while driving, in which case just let it idle for 15 seconds before you shut it off...then figure out why your running lean later.
