carburator trouble!!!!
Old Nov 22, 2003 | 07:05 PM
87transkid's Avatar
Car: 88 Formula
Engine: 350 TPI / supercharged
Transmission: 5spd manual / dual friction centerforce clutch 373 rear end
front butterflys wont open fully when starting engine could it be a vacum leak and if so what hoses do i check and if replace?
Thank you: reader
Old Nov 24, 2003 | 05:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
I assume you mean the choke butterfly (on the top of the carb), and not the throttle plate butterflies (on the bottom of the carb).
It doesn't open fully when first started up. However, it should open up slightly after the engine starts. If it doesn't, the vacuum diaphram choke pull-off may be defective or disconnected.
The choke should slowly and completely open after about 5 minutes of running.
mrbird
Oct 20, 2015 03:43 AM
Jynx88
Oct 4, 2015 08:19 PM
Lmancha96
Sep 25, 2015 08:11 PM
HikoriYami
Sep 21, 2015 07:11 PM
BWilcox
Sep 20, 2015 12:19 PM
