Brabd New 650 DP...WILL NOT idle without choke
Old Nov 26, 2003 | 03:59 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
ok i put it on filled up the float bowls and fired it up...i didnt open the choke so it was extremely rich.. i shut if off and opened the choke all the way and let it run for a few mins..i adjusted the float levels like the manuel says. After i was done with that i figured it would be warm enough to set the idle as well as the idle mixture....so i closed the choke and it died instantly...so i open it up and restart..i closed it slowly and it eventually died..with the choke fully open it idle glass smooth and was a little rich...
withthe idle mixture screws 1 and a half out it was "cloud the neighborhood" rich...so after i turned them both 1/2 back in thats when it idle smooth and wasnt that rich....also with the choke closed it was very saggy and poppy...with the choke fully open it was very crisp and snappy
like i said the only thing i touched was the float level and the idle mixture screws on both side of the primary metering block...i turned them both 1/2 in...
This carb is on a LT4 motor/heads, stock 94 cam
Thanks a lot guys
Rob
Old Nov 26, 2003 | 04:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
So what's the problem?
The choke is supposed to be open at all times except when the engine is cold. If the car runs right with the choke open and the engine warmed up, then .... it runs right.
Old Nov 26, 2003 | 05:21 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Bingo.
The choke should only be closed when the engine is stone-cold.
Old Nov 26, 2003 | 05:26 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
ok my bad..i thought with the little flap open the choke was on..
damn she runs just right then lol...
:hail: :hail: :hail: RB lol
Old Nov 29, 2003 | 05:13 PM
Air_Adam's Avatar
No praise for me?!
Hehe, j/k... good to hear all's well
Old Nov 29, 2003 | 08:51 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
*pats you on the back*.....good job buddy, i guess to guys posted at the same time huh.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Chad Speier
Sep 24, 2015 12:32 PM
buckshot63
Sep 10, 2015 09:15 AM
IROCtometal
Sep 9, 2015 10:01 AM
