62 to 64 jets in Holley what a difference
Thought I would share this with everyone since some of you have the same problem I have. The car would vibrate really bad around 2000 to 3000 rpm. I checked the ignition system real well and found no faults with it. I went the extra step and re routed all my plug wires and put them in looms. I still had the stumble and vibration. I figured what the heck the only think I havent done was check for a lean mis. So I removed to 8.5 powervalve and replaced it with the 6.5 I had with the carb and uped the main jetsfrom 62 to 66. I still have a vibration not as bad. The car pulls much stronger than previous. I plan to go up to 68 primaries since the plugs look too clean still and would rather be a little rich than lean. I did notice a collector gasket leaking. I will fix that first, not sure if an exhaust leak here would cause a problem. What do you guys think oh and base timing is 16 degrees.
Hotrodboba400
12-10-2019 07:07 PM
86CamaroDan
09-29-2015 10:08 PM
