Car is missing
Old Dec 19, 2003 | 09:50 PM
Bandit5's Avatar
Car is missing
I replaced my 305 with the 350 HO Deluxe(Holley 600 vac sec.) about 2000 miles ago. I had the carb adjusted after break in and was running fine. Now that it has gotten colder, it seems to be missing, gets quite bad at higher RPMs under load.
Being new to cars, but not scared to do the work myself, I want to fix this problem. Is there something I can adjust on the carb that could be casuing the problem(maybe increase fuel), or should I look elsewhere?
Old Dec 19, 2003 | 09:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A steady miss like one or a few cylinders, or a more random/general miss?
Steady miss ain't the carb. Could be ignition, valve, something of that nature. A more random/general miss could be a fuel starvation problem, but since you say it only gets worse at higher RPMs, I'd tend to think not.
Old Dec 19, 2003 | 10:05 PM
Bandit5's Avatar
It doesn't seem very steady, but if I want to take off, then it is very noticeable. If I accelerate normally (see: grandmother) than it is fine. I was going to replace the element in my fuel filter since that is cheap, but I need a plan of action if that doesn't work.
Old Dec 19, 2003 | 10:42 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I had to adjust my carb for the cold too. I noticed that when I take off the A/F ratio would be fine untill I get into it a little more,then it would just bog unless I floor it. What I did to fix it was stepped up the Power valve to an 85(8.5" Hg). Car runs great and has no flat spots.
Old Dec 24, 2003 | 09:01 PM
Bandit5's Avatar
Found it.... turns out it wasnt the carb at all. One of the spark plug wirse got cooked against the header. Moved it away and it ran fine. Gonna replace it next week.
hectre13
Dec 11, 2023 08:14 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
MY87LT
Aug 17, 2015 08:43 AM
Exxon Limited
Aug 9, 2015 08:13 PM
