86 LG4 Carb
Old Jan 23, 2004 | 08:00 PM
jensamin's Avatar
86 LG4 Carb
Hi-
I've never done a carb job, however, I've read plenty on the job, and what carb to pick. I wouldn't swap my Q-jet out, but it "needs rebuilding", plus I really want to have SOMETHING not stock under the hood. Anyway, I have a couple of questions I would REALLY appreciate having answered:
1) Will too much CFM be bad for power? I know it would be for gas mileage, and any sort of economy, but if I chose a 750cfm over a 650cfm, would I notice a significant decrease in power?
2) I'm pretty sure I have a manual choke, but I would just like to verify this. (4bbl LG4 w/ 700R4)
3) Do I need to pay attention to something that mentions EGR or not, I read some parts that specifically mentioned "for use with an EGR". Does anyone have a place I can go to see what EGR is?
4) Is the job straightforward- Do I just note the linkage positionings, pull off the old carb + gasket, put on a new one + gasket, attach linkages, adjust idle, and go?
I appreciate all of your help! Thank you!
Old Jan 24, 2004 | 06:04 PM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
i'm in the same boat
Old Jan 24, 2004 | 07:18 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
1. I guess if you go way! To big it could
2. If you have a stock q-jet no you have electric choke and vacuum secondary
3. Do you have emissions? If no EGR is not needed and EGR refers to a valve on the manifold nothing to do with the carb.
4. Pretty much straight forward. If you are going with any aftermarket carb you will need a new distributor that’s not computer controlled and if you have the stock manifold I hear you will need a q-jet to square boar adapter?
Old Jan 24, 2004 | 08:11 PM
pheonix305's Avatar
Car: 1986 Trans Am
Engine: built 305
Transmission: 700r-4 shift kit
why do you need a different distributor when you go to a aftetmardet carb. what sensor in the carb relates to the ingnition and the advance. just wondering because i just made the switch and am breaking in the engine.
Old Jan 24, 2004 | 08:48 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
From what i know they are both computer controlled and instead of vacuum advanced the disttributor is controlled buy the computer. the sensor in the carb is it called a TPS? the green wire in the top? i mean i maybe wrong but i thought you need to change distributors when you swap to an aftermarket carb (none cc)
Old Jan 31, 2004 | 07:37 AM
jensamin's Avatar
If I was to put in a new carb without replacing the distributor, would it royall screw up the timing? Also, are there any tech articles anywhere I can read about what I'm trying to do with swapping out my Q-jet for something else? Thanks
Old Jan 31, 2004 | 08:09 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
here are 2 these are TPi to Carb swaps but the serve same perpous removing the computer.
Swap 1
Swap 2
Old Jan 31, 2004 | 09:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That discussion is going on here https://www.thirdgen.org/techbb2/sho...hreadid=217860 .
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
