help, carb spitting out gas
Car: 84 camaro z28 and 79 trans am
Engine: 305 and 350
Transmission: T5 and TH350
I swap a 350 into my trans am and I'm having troubles with my carb ( edelbrock 750 cfm) because it's spitting out gas and I don't know why is that happening. My family and I built that engine, it has 305 heads, crane camshaft with 275 deg, edelbrock 750 cfm and it has a 180 psi compression.
If anyone has a clue please tell me
I assume you mean that when you run the engine (or attempt to) gas starts spraying out of the vent tubes and gushing all over the intake?
If so, you've got an inlet valve on the carb that is either stuck, has dirt in it, or the float is set way too high (high enough that it never fully closes the inlet valve).
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Or the fuel pressure is way too high. What are you using for a pump? Regulator?
Dialed_In
Aug 20, 2015 01:45 PM
