how would i upgrade my stock q-jet
Old Feb 14, 2004 | 10:23 AM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
Transmission: automatic
I have heard that my stock q-jet can manage alot of power if you do a couple things to it, but what are those things? I wanna put a 350 in place of my 305 and am afraid that my carb wont be able to handle it.
Old Feb 15, 2004 | 03:14 PM
406-IROC's Avatar
Car: '86 Camaro
Engine: 406 Small Block
Transmission: 4 Speed
Axle/Gears: 3.45
Re: how would i upgrade my stock q-jet
You're Carb will easily handle it. Quadrajet's found on 305's had up to 795-cfm, with some even finding their way over 800. When you install you're new 350, you'll have to go the ole 'trial and error' method..... and experiment.
You'll need a new set of metering rods, and a decent mechanical fuel pump. Don't forget to adjust you're stock fuel float, otherwise you'll find yourself bogging and stalling.....
Old Feb 16, 2004 | 05:41 PM
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
Should work fine. Q-jets are self compensating. The primaries will work just like normal. The secondary air valves will open more on the 350 than the 305 allowing more air and also more fuel (via lifting metering rods higher). I wouldn't be suprised if the Q-jet in stock calibration couldn't be used on a 454. If you are worried about leaning out find some DR rods off a vin code H 305 in a 1982-1984 chevy van and a "F" hanger from a 1988 cadillac brougham with an olds 307. Works real well.
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
