tuning for boost
Old Mar 4, 2004 | 10:27 PM
topless89rs's Avatar
Engine: 5.slow
tuning for boost
i have a 305, edelbrock 600 cfm carb, edelbrock performer intake, stock cam for now, turbo manifolds and a single gn turbo, i'm hoping to run about 6 psi of boost but i have no idea how to tune the carb to run with boost. i built a box for the carb to sit in. i will be using a boost referenced regualtor to raise fuel pressure with boost. any tips or womewhere to start?
Old Mar 5, 2004 | 01:24 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I don't know much about it, but one thing you'll have to do if you're pressurizing the entire carb is replace the hollow brass floats with nitrophyl ones that won't collapse under pressure.
Old Mar 5, 2004 | 11:11 AM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Re: tuning for boost
6 PSI should not be too much of a problem. Jet it a bit rich on the secondary side just to be safe.
A wise investment would be some sort of boost retard ignition. MSD and Crane both make what you want. Detonation is your biggest enemy.
What compression ratio will you be running? What pistons? Don't get greedy with boost unless you have some good forged pistons in there.
Old Mar 5, 2004 | 11:50 AM
Engine: 5.slow
its a stock rebuild 305 with about 5,000 miles on it. its a tbi motor right now but i'm swapping over to a carb. will i be able to get away with just retarding my base timing a little bit without usinmg a boost retard unit? like if i just retard the timing a little to begin with? i will run about 6 pounds of boost
Old Mar 5, 2004 | 06:53 PM
Car: 86\92 Mutant
Engine: 355CI 430HP
If you're going to the expense of putting on a turbo...spend a bit more and get a proper boost referenced timing system. You're going to need something anyway...because you need more spark power when you start to run boost. Even though I prefer then Crane units over a basic MSD 6AL units ( Full digital circuitry vs Analog ) you can pick up a used MSD pretty cheap at a Swap meet or in the Buy&Sell. Add on a turbo retard module and you're all set.
Retarding the base timing is a crutch. Will kill the bottom end and increase turbo lag...although you shouldn't have much lag with stock compression pistons only 6 lbs of boost. Much better to run a proper curve...limiting the total timing as RPM rises and boost builds. Only way to do this is with a Boost retard system.
What are you going to run for a distributor? Is it the Stock Electronic Advance unit? Can you keep the knock sensor?
$750 L98
Feb 1, 2025 02:25 PM
