looking to get an air/fuel meter, ?'s
Car: transam, el camino
Engine: 415
I read that a wide-band 02 sensor is the best way to go. Will the wide-band oxygen sensor work with any type of air/fuel guage?
Has anyone had experience with Cyberdyne guages?
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
a standard A/F ratio gauge is designed to monitor a very narrow range of output. It will not display the accuracy that the wideband O2 puts out. You'll need a display(gauge) that is designed to work with a wideband O2.
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
Narrow Band (NB) O2 sensors hook up directly to the A:F gauge. They use a 0-1 volt signal.
Wide Band (WB) O2 sensors need a special Controller/Power Supply and usually outputs a 0-5 volt signal.
Here is a Site that is probably the Internet Bible of WB O2 sensor info:
http://www.megasquirt2.com/PWC/index.htm
Unfortunately it’ll be a few months before they have a Controller for sale.
