Holley Mechanical Conversion - did a search
Old Mar 23, 2004 | 03:31 PM
dennis6's Avatar
Car: 1991 Camaro RS
Are the passages to the secondary pump that are missing in the VS carb in the main body or base or maybe both?
Old Mar 23, 2004 | 04:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Neither.
Nothing in the base of a DP, for that matter.
Old Mar 23, 2004 | 05:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Conversion to manual secondaries, 2 easy steps:
1. Sell vac sec carb
2. Buy man sec carb
There's no other way to turn one into the other. That has something to do with why they're 2 different models. (4150 / 4160)
Old Mar 23, 2004 | 06:43 PM
five7kid's Avatar
Well, I agree with your conversion steps, but Street Avengers are model 4150 VS carbs.
http://www.holley.com/HiOctn/ProdLin...C/0-80770.html
Old Mar 23, 2004 | 09:40 PM
dennis6's Avatar
Car: 1991 Camaro RS
Ok, sorta done the conversion steps. I was trying to get a cheap 800cfm DP. I needed a 4165 and not the 4150.
I ended up purchasing a 4165 off of ebay, but its a 650. I have been told I can swap the main body and rejet. I hope I was told right.
Old Mar 23, 2004 | 09:43 PM
five7kid's Avatar
For a 4150 or 4160, yes. Like a Proform main body.
For a 4165, never heard of it.
Old Mar 24, 2004 | 12:27 AM
dennis6's Avatar
Car: 1991 Camaro RS
I am just planning on using a stock holley 800cfm 4165 main body. I checked the base bore on the holley site and its the same. I just hope everything else will line up.
4165 for anyone who doesn't know is just like a 4150 with a Spreadbore base instead of a squarebore.
Oh, the carb has the non race square bowls. Can I convert to the race bowls? Some 4165 carbs came with them, but I rather have the quick jet bowls.
Old Mar 24, 2004 | 04:18 AM
dennis6's Avatar
Car: 1991 Camaro RS
As for the bowls, doing some offsite research I found out that 4150 bowls will not work, because the pump passages won't line up with the metering block.
I guess the question now is, will a 4150 metering block work with a 4165 main body?
Old Mar 24, 2004 | 04:29 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I wouldn't do a conversion, they never work properly. Just sell what you have and get a real mechanical secondary carb.
Old Mar 25, 2004 | 12:33 AM
dennis6's Avatar
Car: 1991 Camaro RS
The 4165 is a real mechanical secondary carb. Its going on a bucik motor and the 4150 would require an adapter. There are not many intakes available for Buick 455 motors and the eldebrock intake, the only eldebrock intake for a 455 buick is squarebore.
Old Mar 25, 2004 | 09:25 AM
five7kid's Avatar
The only experience I've had with those spread-bore Holleys was over 20 years ago, and it wasn't a pleasant experience (I believe it was a 750 DP, which they don't even make anymore).
You might want to get RB's take on that carb (surprised he hasn't jumped back in). He seems to have had more luck with them.
Old Mar 25, 2004 | 02:34 PM
dennis6's Avatar
Car: 1991 Camaro RS
I remember something you said about that carb. I am just hoping you had got a bad model and it wasn't all squarebore DPs.
Old Mar 25, 2004 | 05:14 PM
Air_Adam's Avatar
I've heard good things about the #6210 Spreadbore DP. Its a 650cfm.
Old Apr 5, 2004 | 03:04 PM
billhelton's Avatar
Car: 85 Sport Coupe
Engine: 355ci
Transmission: TH-350
Sorry to burst your bubble, but the 4165 is NOTHING like a 4150. I have a friend with one and even Holley had to research for part number just to replace the squirter.
Old Apr 5, 2004 | 07:03 PM
dennis6's Avatar
Car: 1991 Camaro RS
Yeah, found that out. I have been in contact with holley.
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
angel2794
Sep 8, 2015 06:22 PM
Slush92RS
Sep 2, 2015 08:56 PM
stalkier
Aug 21, 2015 01:54 AM
